3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
too much noise/white spots in 3ds max vray render
14 REPLIES 14
Message 1 of 15
139872 Views, 14 Replies
Hey guys, I have some trouble with my renders, even with very high resolution i get these grains(noise),white pixel spots all over my render.. what could be the issue? thanx !
14 REPLIES 14
Message 2 of 15
kgokhangurbuz
Hi;
Can you please share your scene with me so i can take a closer look?
Regards;
Message 3 of 15
rendermaster
would you mind to post a screen shot of your settings for us to properly evaluate the problem
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Message 4 of 15
Ihno
in reply to: rendermaster
Definitely too less primary samples...
Do you use the standart setting of V-Ray?
If yes, in the Progressive image Sampler rollout is a parametar called render time (min). Turn it to zero and V-ray will render as long as it needs to reach the Noise Threshold which is exposed in the same rollout. To ajust how clean it gets, simply lower the Noise threshold; 0.005 should give you a quite clean image.
Message 5 of 15
in reply to: kgokhangurbuz
Hey..I have attached the render scenes below .. Thanx
Message 6 of 15
ok i attached the file below.
Message 7 of 15
I have test rendered this scene with a simple vray sun and sky, no hdri yet added. so the only settings i have touched so far are - GI,VRAY-color mapping+global switches , settings-  (i have attached the settings screenshots below.)
this also happens on a very standard render of a wall with some grass and a simple sun and sky,still the same issue happens.
Message 8 of 15
in reply to: Ihno
Thanx for the response.. i changed the settings in  Progressive image Sampler , a much different outcome. however it is still unclear. i have attached the changes below.
Message 9 of 15
kgokhangurbuz
Hi;
I inspected your scene.
First of all, this is just a sampling issue, you are not getting enough sampling for your object(s).
Can you please try this:
Go to Rendering > Render Setup > V-Ray
Under Global DMC rollout, increase the amount of Subdivisions Multiplier to "4" (this will multiply all your subdivisions amounts in your scene by 4
Under Bucket Image Sampler Tab, Increase Max Subdivisions amount to 100.
then go to GI Tab
Under light cache settings, change scale type from screen to World.
Share your result with me after these changes please.
Regards;
Message 10 of 15
Ihno
Since youre using 3.2 you should really take a look at this tutorial:https://www.youtube.com/watch?v=tKaKvWqTFlw
If you have a license simply download the 3.4, it improves the sampling alot.
Since 3.3 there is usually no need to do anything other than change the noise threshold and rendertime (In case of progressive).
This is a very good post 3.3 sampling tutorial: https://www.youtube.com/watch?v=OS3XP9TDCwM
@kgokhangurbuz's suggestion is very good 😉 as usual. Dont want to call it invalid. 🙂
I think the Bucked Image sampler rollout was called Adaptive in 3.2 Also he would need to change the type from progessive to Adaptive first.
Sorry for being a smartass. Smiley Embarassed
The tutorials will make you able to setup the sampling for most scenes yourself.
Message 11 of 15
kgokhangurbuz
in reply to: Ihno
Yes, I'm sorry that i didn't mention the earlier versions rollout names but the 3.4 versions only, thanks for reminding and pointing that out, @Ihno!
With the 3.4 Version, all bucket sampling modes (Adaptive, Adaptive Subdivison and Fixed options) are combined under Bucket mode. Therefore there are only two rendering modes are shown as: Progressive and Bucket modes.
Message 12 of 15
Hello.. Thanks for the response..
I worked on the DMC and changed the remaining settings as you mentioned .
There was a major change !! I have attached the image below.However the white wall still has some very noticeable spots, could that be a material issue perhaps ? and also can you spot the black lines on the edge of the walls .. ?
well up to here, there is a big difference from where i started, so thank you very much!! Cause i did solve the white grainy spot issue .. any further tips on the above issue would be great 🙂
regards,
Message 13 of 15
in reply to: Ihno
I will check the links out and try to update to 3.4.. much appreciated!!
Message 14 of 15
thanks it was helpful
Message 15 of 15
dpsd1989
in reply to: Ihno
Hi!
I am facing the same problem.
I use a silver reflection texture material for teh curtain in my scene. Also the quality is very low even that I set the resolution (noise) 4000 x 2250
