so I have a classic roof where I apply a wood texture.In viewport is totally visible but when I render,it has a greyish color and looks like reflecting the vray (default) sky. No textures are missing and the shader is totally functional as it is also been applied in other objects. The entire model is made in autocad 3d and render in 3dsmax 2019 and vray 5. Any idea?
sounds a bit like the material you are using might not work together with the renderer... did you try another material?
