When baking normal map in 3ds max 2024, artifacts appear on the normal map in the form of streaks and spots. I don't know how to overcome this problem, as well as to find a solution on the Internet. I baked the normal map through bake to texture, and through render to texture, the result is identical. When exporting the same scene to 3ds max 18 weight, the normal map is baked correctly.
