3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Spherical gradient map?
3 REPLIES 3
remainz
719 Views, 3 Replies
remainz
Is it possible to create a spherical gradient map?
As opposed to the linear or radial gradient maps already available. 2d maps only.
Im using procedural noise maps (which are volumetric) with particles but I need a simple gradiated sphere too.
thanks remainz
thanks remainz
3 REPLIES 3
i.buksh
in reply to: remainz
i.buksh
Community Visitor
Community Visitor
Would love to know an answer to this please. It seems you can perform a spherical gradient very easily in cinema 4D but can't quite see the same function in 3ds max.
Cheers,
Cheers,
wernienst
wernienst
With Gradient Ramp Map:
Cinema4D: Spherical Map = MAX: Radial Map
Cinema4D: Radial Map = MAX: Spiral Map
i.buksh
in reply to: wernienst
i.buksh
Community Visitor
Community Visitor
Thanks for the response.
I believe cinema 4D has a unique 3D Sphere gradient that I'm attempting to replicate in 3ds max. I've used camera projections etc but just wondering if I'm being a bit silly?
The radial gradient in max does not perform the same as the 3D Sphere gradient which is like a 3D sphere is penetrating the mesh and giving varying gradients in the viewport. So you can control the effect by navigating the mesh.
Cheers
Cheers
