some hidden shader in 3dsmax
WHY autodesk hidden these shader
Richard.Vivanco
Are you using the correct render engines for this shaders?
Do you try to use the shaders?
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Website | Youtube | LinkedIn
I found the SSS2, the effect is very good
CAMedeck
Some shaders get hidden because they are not thoroughly tested, or have shown some instability in the software.  Use at your own risk.
Chris Medeck
You mean the shader will begin in 3 ds Max version be integrated
CAMedeck
Not always.  Some hidden shaders do make it into later versions of 3ds Max, but some don't.
Chris Medeck
So what does it matter?Anyway, 3dsMax is full of bugs, I am used to the BUG
