3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Simple question about UnwrapUVW Modifier
3 REPLIES 3
BenediZ
358 Views, 3 Replies
I wanted to get a simple planar projection from an shader with Ramp on a object.
It seems a bit cumbersome and weird in 3dsMax:
I set the Map channel on 2 and used also a Unwrap UVW Modifier on Map channel 2.
However, when I  create a planar mapping, nothing happens, the ramp is not projected through the object.
(Also not in render)
I am normally used from Maya, when I move  the projection plane, I can see exactly what happens, but here nothing happens, the mesh shows random results.
Many thanks for explanation!
Labels (1)
3 REPLIES 3
oliver
in reply to: BenediZ
For such a simple use try the UVW Map modifer. Here you can even animate that gizmo.
BenediZ
Thanks.
I still wonder, why this did not work with UnwrapUVW... If this is an "expected behaviour" or kind of a bug...
Try to select all polygons and then apply the planar mapping
