Hi
I'm currently rendering a model using V-Ray and I'm having trouble with the buckle material. It's silver, but it's showing too much black. I've even struggled to adjust it in Photoshop on my final render. I've tried messing with some of the options, but nothing appears to be changing it in the interactive render. I've also tried re-positioning and adjusting the size of the light plane. Any suggestions on how I can reduce the blacks? Thanks.
Give it something to reflect (except light)
Now it looks "psychically correct" - if you throw it in (outer) space
The black is coming from the environment which looks to be all black. So for example, if you put something in the environment (eg., walls, furniture, etc) with different colors then that will be reflected in the metal material. If you don't want to model things just for showing your textured character, you can place an HDRI map in the texture slot of a Vray dome light. Check out tutorials on using HDRI lighting in Vray. There's a few here:
This is like what you see in Substance Painter when you are working on textures because there is an HDRI Map in the environment in SP that gives the reflected materials something to reflect.
Ahh, I see. Gotcha. Makes sense. >_< From following a project book I have, the 'environment' has just been given a VRayMtlWrapper with a VRayMtl base just for capturing the character's shadows. I've only been collecting the different render layers for the character, so everything around it is black.
