Solved by fla3d. Go to Solution.
I suggest you use the Physical Sun & Sky together with the sun positioner, with Arnold Physical Sky you can't use the positioner and can't set a ground color, the only reason I think I would use it is to render in Arnold standalone, otherwise go with Max Physical Sun & Sky, it's fully compatible with Arnold and it's easier to position in the scene.
Thanks! I'll go with that advice.
