Hi!
I have an issue while rendering in 3ds Max 2016 / Vray 3.20.02. The geometry appears cracked and some parts are not even showing in the frame buffer. Please find attached the files containing screenshots for the issue. The viewport screenshot looks normal, but then when I hit render it looks like one of the Frank Gehry designs. Even the material editor looks weird and it's 2D circles, not 3D spheres. Please help, I'm new to 3ds Max and can't fix this bug by myself.
Kind regards
Solved by Richard.Vivanco. Go to Solution.
The problem persist if you create a camera and render this viewport?
Another solution can be to merge your project into a new scene. Drag and drop your project from windows explorer into a new scene and choose merge option.
Thanks, it worked when I merged the project into a new scene.
Milan
