3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Rendering anime atyle characters
7 REPLIES 7
Message 1 of 8
22931 Views, 7 Replies
I'm starting my first, real 3DS Max animation project. It's supposed to be a 3D Animattion with an anime art style, similar to RWBY or Naruto Shippuden. Basically, I have the character modeled, and I'm using Ink 'N' Paint to give it the look I want. I like the actual texture (Created in Photoshop) but my problem is that black outline. I can't get it to work perfectly. I either don't get enough detail at certain angles, mostly with the ear and jaw line, or I get the detail, but fuzzy and thick outlines by the chin. I have variable width turned off, started playing around with the under/overlap numbers, but to no avail. I will include screenshots of my issue.
7 REPLIES 7
Message 2 of 8
ekahennequet
Have you looked into using mental ray's Contour Shading in combination with Ink 'n Paint?
mental ray Contour Shading
http://docs.autodesk.com/3DSMAX/16/ENU/3ds-Max-Help/index.html?url=files/GUID-797FBC38-E08E-41DF-9D0...
Below are few tutorial links:
Technique 3: Using Ambient Occlusion and Contours in mental ray to create NPR’s.
https://area.autodesk.com/blogs/eddie/technique_3_using_ambient_occlusion_and_contours_in_mental_ray...
Technique 4: Using Ink and Paint shaders to create NPR’s
http://area.autodesk.com/blogs/eddie/technique_4_using_ink_and_paint_shaders_to_create_npr_s
This one seems to use the combo method, but I've not watched it.
http://www.youtube.com/watch?v=2zpg3dYLr8A
Message 3 of 8
in reply to: ekahennequet
I believe this has, more or less, fixed my issue! The line quality is SO much better, though I still don't get much detail in the side view around the ear and jaw line, it DOES give me more detail in some more perspective views. You were incredibly helpful, and I thank you for that!
Message 4 of 8
ekahennequet
You're welcome. The Help file doesn't have too many examples, but I'm sure you will find a better alternative than using just Ink 'n Paint by playing with the mental ray Contour settings. Good luck.
Message 5 of 8
Steve_Curley
If you haven't already, take a look at this blog post - it's a bit old now but contains some really interesting stuff on MR and on Ink'n'Paint. Well worth a watch (though it's quite long).
http://area.autodesk.com/blogs/garyd/non-photorealistic-rendering-npr-techniques-in-3ds-max
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 6 of 8
ekahennequet
in reply to: Steve_Curley
That's great, Steve! Thank you. I've not seen that one. Bookmarking it now. 🙂
Message 7 of 8
Steve_Curley
Yep, it's a good one. Watched it a week or so back. Will do so again when I've time to actually try out some the stuff in there 🙂
Max 2016 (SP1/EXT1)
Message 8 of 8
I am in very big trouble i am to complete my assigment in 3ds max. 8 am using 3ds max 2011 and i wat to make a 2d effect explosion but i am not getting a right thing please help to make 2d effect explosion. Plz
Technology Administrators
