Rendered Object - Geometry visible on flat surface?
jgjYRRKE
jgjYRRKE
Hello everybody.
I am working on a rendering of a piece of cleaning equipment.
In the middle there is a water/chem mixing chamber and the chamber have a lid (image)
The lid is 2 materials. Side and front.
The front is metallic with anisotropic radial brushed surface.
It looks very bad. Like the edges are visible, even tho the surface is flat.
How can I solve that annoying problem?
3DS Max 2024 - Arnold Renderer.
RobH2
Looks more like a modeling issue than an Arnold one. You say the surface is flat and it probably is. Do all the faces have the same 'Smoothing Group?' How about the UVs. Do you have a nice square planar UVW on the face?
Sometimes when a mesh has a ton of edges really close together, like yours does between holes in your face, you get artifacts like what you are seeing. It's just too many parallel edges and it doesn't render cleanly.
I've had situations like this and the only way I could solve it was to remodel the face. You might try detaching the face and then using the 'Retopology' modifier to rebuild it. If your face's outer edges and hole edges don't move, they will stay clean. That way the new pure poly face will render the anisotropy correctly.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
jgjYRRKE
I think you are right.
The model is made in Inventor and imported, so the surface is not optimal.
I will try optimizing it or find a workaround.
Thank you.
