3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Render Pauses on Windows 10 Lock Screen
3 REPLIES 3
4969 Views, 3 Replies
I set up a 300-frame render before leaving the office last night.  Average frame time 18 seconds.
My machine is set to display lock screen after 5 minutes away (company policy).
When I unlocked my machine this morning, the render had barely completed a quarter of the sequence, saying the last frame time was 15 hours.
The next frame was 18 seconds again.
Is there a way to ensure this doesn't happen again, with Max continuing to render even if Windows is locked?
Thanks.
3DS Max 2018.2
Arnold Renderer
Windows 10 Pro v.1703
Thanks.
3DS Max 2018.2
Arnold Renderer
Tags (1)
3 REPLIES 3
jon.bell
jon.bell
Hi Brittnell,
Thanks for your question. I think what's happening here is that Windows 10 is suspending CPU processes while it's in sleep/lock mode.
You should be able to go into your Windows Control Panel > Power Options > Edit Plan Settings, and change your Computer's Sleep mode to "Never." (You could also click on the Change advanced power settings and customize your PC's power settings if necessary.)
Unless I'm mistaken, your PC will still go into "lock" mode after 5 minutes, but not officially go to sleep behind the lock screen, so any CPU-intensive processes like rendering will continue.
Please let us know if this helps!
Best regards,
Jon A. Bell
Autodesk Technical Support
Jon A. Bell
Senior Technical Support Specialist, 3ds Max
Hi Brittnell,
Best regards,
Jon A. Bell
Jon A. Bell
in reply to: jon.bell
Thanks Jon.
It's a brand new machine, and I didn't do the actual set up, so didn't realize they had left these power-saving options on.
Really appreciate the reminder to look at these settings. It seems to have done the trick.
Cheers,
Britt
Thanks Jon.
Cheers,
Britt
jon.bell
jon.bell
Hey Brittnell,
Woo-hoo! Glad that worked for you! (My pet peeve with Windows 10 is when I've set it to not auto-update my machine overnight, but it sometimes resets that and reboots my machine when I'm doing a rendering. I don't care if aliens are invading Planet Earth and rebooting my PC is the only way to stop them -- I don't want Microsoft to reboot my machine without asking my permission, period.) 🙂
Good luck with your CG work!
Jon A. Bell
Hey Brittnell,
Jon A. Bell
