Hi, Currently I'm working on a bike. I know this is not the right place to ask this question but whenever I rendered in 3ds max 2016 I always got a black render. It would be great if someone can tell me. Last time I rendered in mental ray, Again I'm rendering this file with vray.
thanks in advance.
i looks like you haven't place any vray light on the scene.. try that and test...
hi thanks for the reply... if you have seen the reference I have applied all the light in the scene.
Did you try increasing the multiplayer value of the light?? can you post a screen of the properties lights?
HI...finally problem is resolved..Lighting wasn't working with (renderer - v-ray rt ). I changed it to v-ray adv...
but now I have one more problem with v-ray material whenever I apply nm to my material it gets pixelated.
MMMM.. yes!! Vray RT only works with GPU.. and the rendering is with Vray Adv... (cpu)...
when you say pixelated you mean this?
Are you using some smooth or mesh smooth properties??
