Raytrace rendering problem max2020
Message 1 of 16
I have a problem with rendering old files in max 2020.
I'm using a default scanline renderer and in max 2019 it's still very quick but when opening the same file in max2020 it needs like 20x more rendering time! What i can see is that the raytrace renderer is calculating over and over again with each line that is being rendererd instead of one calculation per rendering as it does in 2019...
Does anyone have an idea of how to solve this?
THX Frank
Replies (15)
Message 2 of 16
hagen.deloss
@Anonymous
Great to hear from you on the forums! I am curious if you are able to pass along a scene file you are experiencing issues with, I can send you a private file sharing link via PM if you would rather not have your files public.
What other elements are within the scene besides materials, geometry, and lights? It could be that a particle system was reworked in the newer version of Max and needs to be remade, or a similar issue.
I'm looking forward to helping narrow down the cause of the slow rendering issue, but need a little more information 😄
Talk to you soon!
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 3 of 16
hagen.deloss
Hi @Anonymous
Any ideas or questions on my previous post? It would be helpful if you had time to give an update, that way other Community Members can benefit from your process 😄
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
Message 4 of 16
Hi Hagen.deloss, thx for your reply
Attached you'll find two screenshots i made rendering the same max file.
The main issue seems to be that the raytrace engine in max 2020 needs to calculate again with each line rendered (default scanline)
The elements in my drawing are quite standard, just some standard materials, mappings and lighting. i'm not using any plug-ins or particle systems.
Does this help?
Message 5 of 16
hagen.deloss
@Anonymous
Interesting, I think it would be most helpful if I could test a sample scene that you are encountering this issue with, as I am not experiencing any issues rendering between my 2019-2020 scenes. Feel free to attach a scene to your next message, or send me a private message with a filesharing link.
Have you tried disabling Raytrace, or lowering the Ray Depth Control within your 3ds Max render settings?
Let me know of either of these options work for you, I look forward to hearing back!
Hagen Deloss
Message 6 of 16
hagen.deloss
Hi @Anonymous
I wanted to pass along a few other suggestions, in case you are still having this issue.
Here is an article on how to optimize rendering with raytrace turned on
Additionally, you can turn off those messages if the pop-up bothers you.
I hope this helps!
Hagen Deloss
Message 7 of 16
Hi@hagen.deloss ,
I'm a colleague of Frank. I looked into this problem as well. First of all I want to reply to your suggestions.
@hagen.deloss wrote:
Hi @Anonymous
This is Mental Ray related. Our problem is in scanline only.
It's not the messages. It renders cleary slower.
I recorded rendering a simple scene to see the difference. Attaching this as well as the scene itself.
Message 8 of 16
hagen.deloss
@Anonymous
I really appreciate the video, and additional information!
I can reproduce this issue with the test scene you have provided.
Currently the scene you provided has a standard material with a raytrace property assigned to it. i opened it and tested a few things in Max 2019 and 2020, just to be thorough.
  • I assigned a Raytrace material to the objects. The test render had the same slow render speed in Max 2020.
  • I attempted to assign a physical material with a high metalness setting to the same effect as well.
  • I then recreated the scene in Max 2020 and assigned the same above raytrace materials and properties, to the same slower render time.
  • It may be that raytrace in scanline may be slower in 3ds Max 2020, but i wont know anything until i test more.
I will see if my colleague experiences the same, talk with someone in QA, and keep you updated on how those conversations go!
Hagen Deloss
Message 9 of 16
Thanks @hagen.deloss
Looking forward to the outcome
Message 10 of 16
hagen.deloss
@Anonymous
I just wanted to keep you updated, this was just logged by the QA team and is now in the development teams backlog. Thanks for helping document this issue, I will update you if/when development comments with an update regarding the issue.
Hagen Deloss
Message 11 of 16
Hey @hagen.deloss
I was wondering if there were any updates on this issue.
Thx in advance,
Nils
Message 12 of 16
Any developments here? I've just updated to 3ds max 2020 and am having the same problem. I'm trying to render a scene that already takes 3 hours in the older version, and I can't get anything done in 2020. This is unusable as it is.
Message 13 of 16
madsd
I don't think this sits very high on priority lists.
More and more things does not work with Scanlines and there is a deeper meaning with that, looking forward.
We have seen other initiatives in max get phazed out over time.
The problem could be rather complex, or very easy to do though, so yeah ~
Not the most sexy answer, I know.
Message 14 of 16
hagen.deloss
Hi @Anonymous
Sorry for not getting back to you sooner! It looks like the Max rendering team has looked into this, and a fix will be included in a future update to 3ds Max.
I will update you when that is released 😄
Hagen Deloss
Message 15 of 16
hagen.deloss
Hi @Anonymous
I believe this issue has been resolved in 3ds Max 2020 update 2, would you be able to confirm this while rendering in your specific scene?
Hope you are doing well 😄
Hagen Deloss
Message 16 of 16
Hi Hagen,
That's great if the rendering problem has been fixed. Unfortunately, my company decided to discontinue Autodesk maintenance last month due to the price increases, so I don't have access to 3DS Max 2020.2. If the fix isn't going to be released as a patch or hotfix to 2020.1, I won't get it.
