Problem with viewport and Physical materials
Hi all,
I have a problem viewing physical materials in my viewport.  Here is a simple test scene:
The plane is has no material at present and shows fine, but as soon as a physical material is applied as I have done with the box, the object turns black.
There is nothing special about this physical material, just a template glossy paint.  The same happens with any physical material.
I have tried every viewport display setting with no luck.
I am using 3dsmax 2018, but the same issue existed for 2017 I believe.
Nitrous 11 keeps crashing so I use Nitrous 9.
Please help! 🙂
jamesw
What render engine do you have it set to? Its mainly for use with the Art renderer but should be compatible with the other engines out the box.
I'm Having similar issues with the physical materials,
Arnold rendering set in this scene
I ve got the exact same problem with physical material. It just displays black in the viewport so it is hard to see those objects after assigning the physical material to it.
