Hi All,
I keep getting errors on the Deadline and my local machine in just a few frames of the whole animation.
dumpuserinfo.xml showing:
Error accessing UPI repository in the 64-bits registry
deadline is showing:
Error: FailRenderException : RenderTask: Unexpected exception (Monitored managed process "3dsmaxProcess" has exited or been terminated.
or
Error: FailRenderException : RenderTask: Unexpected exception (Trapped SEH Exception in CloseCurRenderer(): Access Violation
I think I located the problem it is a forest pack or one of the forest pack trees but I can't find any solution. It is rendering sometimes ok, but most of the time it crashes for no reason. It is a linear animation with not much change but a heavy file. Other than that I got the same assent in other files more complex and they are rendering ok. I have tried a new file and setting nothing works.
Fiex just removed the broken object, The geometry somehow was damaged, not in a visible way still do not know what was wrong.
