- Mute
- Permalink
- Report
As stated above, when rendering PNG output from Max 2014, quite often the beauty pass will render out just fine, however the additional render elements will be corrupted upon saving out. They display properly after the render has finished eg. when they pop up on the screen at the end of the render but the saved file is not usable.
I initially thought this may be a problem with the network on the renderfarm here at work, however I am now getting this problem when rendering from my local machine to my local disk. The only workaround I have found for this is to switch to any renderer other than MentalRay and then switch back and to delete all the render elements from the list and then add them all again.
Obviously this is becoming really tedious, so any help would be appriciated.
below is the alpha element that gets saved out....clearly corrupted!
Will
