3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Please help! Float RGB Modifier not working in Arnold
4 REPLIES 4
Epicguygaming13
383 Views, 4 Replies
Epicguygaming13
Hello! I have been following the Arnold Toon Renderer Tutorial "Making of Sophie" and I am having a lot of trouble. Currently, I am trying to make a gradient to color her eye. However, the float RGB modifier isn't working.
As you can see, the material in the preview has a gradiant while the rendered version does not. This works on boxes but not on the spheres. Any help could be appreciated.
4 REPLIES 4
Epicguygaming13
here is the scene file
CiroCardoso3v
First thing is that you need to connect your toon shader to a Map to Material and not to a standard material. Then you assign the Map to Material to the mesh.
Also, you need to detach the pupil and apply an UVW modifier. I am uploading a new scene.
And some shameless self-promotion, but I will be doing a talk at Autodesk University about Arnold Toon Shader for 3ds Max.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Ciro Cardoso
Epicguygaming13
Thank you for the solution, I cannot currently open it as I am in 2020 but I will update versions. Also what is autodesk university? I am interested in learning how to use the toon shader
CiroCardoso3v
Saved on 2020
https://www.autodesk.com/autodesk-university/
Ciro Cardoso
Saved on 2020
Ciro Cardoso
