3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Parallel shadows
2 REPLIES 2
497 Views, 2 Replies
Parallel shadows
Hi guys! I'm new on the forum.
I'm wondering if there is any possibility to have parallel shadows.
I'm using vray and so I used the "vray sun", but. unfortunately the result is not what I was aiming for 😞
Here you can see attached my test.
As you can see the shadows are diverging, while I'd like to have them casting straight down. I tried to use all the other type of lights but it didn't work. I changed the distance and size of the light but nothing happened.
Does anyone know a solution for this?
Cheers 🙂
2 REPLIES 2
mark_aldred
Did you try the standard direct light? That'll do it usually.
Noren2
Sounds a bit like you are referring to the perspective of the camera rather than the shadows being parallel, which they should be with a V-Ray sun. Try using an orthographic camera (or a very narrow field of view / high focal length from far away).
Technology Administrators
