OSL: Randomized Bitmaps broken?
Dantetron
Dantetron
Hello!
Is anyone else getting just a black color instead of the default number template when trying to use the "OSL: Randomized Bitmap"?
It also appears that anything that goes into the "file name 0:" slot just displays black. The other slots display properly.
I then get a slew of "invalid image files" errors when I use the plugin.   Yes- I've tried many different textures and file formats with the same results.
I'm using:
3D Studio Max 2023.1
Arnold 5.3.2.6
RTX 3080
Windows 10
CiroCardoso3v
This OSL node works by randomly placing a set of bitmaps on top of the first layer. You always need something as a base layer and then you build your shader on top of that.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Dantetron
Correct. As mentioned above, anything I put on the first layer only shows as black. Every other layer displays properly.
