3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Open EXR Render Elements and Z-Depth Advice
2 REPLIES 2
1023 Views, 2 Replies
Can anyone explain to me the difference between the standard 'Save to file' process vs using 'V-Ray Raw'?
I'm trying to save an EXR with various render elements including Z-depth and have so far observed the following:
1 - When using the standard 'Save to file' dialog and selecting EXR I can then specify multiple render elements and Z-depth as a buffer. This however only seems to create an EXR with the RGB, Alpha and Z-depth when extracting the channels in post, none of the other elements (specular, lighting, reflections) appear to be present as channels.
2 - When using the 'V-Ray RAW' save method I can choose all of my render elements and these are all then present when I extract them from the EXR in post (AE using ProEXR) but I can't see the Z-depth buffer anymore.
Thanks for your help
I'm using Max 2019 and V-Ray Next
Tags (3)
2 REPLIES 2
Francisco_Penaloza
Francisco_Penaloza
I would recommend using the V-Ray raw to EXR output, this will warranty all compatibility with V-Ray elements.
All the channels will be saved in to a single EXR file, then you can use https://www.exr-io.com/ to open all passes in Photoshop. Other software such as Fusion or Nuke will nativelly read all these passes.
If you rather save each element in a separate file you can use the separate render channel option, also in the V-Ray window.
If you use 3D Max save as then things may get confusing, also 3D MAax implementation of multi-passes into a single EXR (inside the default save as file for 3D Max) is not fully compatible with V-Ray elements.
in reply to: Francisco_Penaloza
Thanks Francisco,
It would seem V-Raw Raw is the way to go then. Keeping all render elements in a single EXR is exactly what I was looking for. The only issue I appear to have with this method is that when I have fog/atmosphere in the scene there doesnt appear to be a way to exclude it from the z-depth, which causes issues with my DOF in post.
I thought I had found a way around this by using a 'deep' exr but the z-depth renders a little strange with this method.
Thanks Francisco,
