Object with Transparent material renders with black background
Alan_WP
Alan_WP
Good day everyone,
I have come across an issue, unsure what the cause is, I have researched and checked all the obvious culprits listed within the forums and Autodesk articles.
  1. The material is a Arnold Standard surface,it  has no maps and is part of a multimaterial.
  2. I am using GPU Arnold 5.9.1.1
  3. 3ds Max 2027
  4. Export format .exr (viewed in Photoshop using EXR-IO).
Below you will find screenshots of the settings. I would greatly appreciate it, if someone has any ideas to share.
Many thanks in advance!
Alan_WP
Hello All,
I found the culprit, there was no opactiy set within the material:
Originally this was white. I used the MAXtoA.mat librry'Thin Plastic' as a basis, as it looked transparent in the renderings, I figured, it would be, as it is from a material library from Autodesk. Unfortunately, it isn't truely transparent. If I have made a mistake somewhere, please feel to correct me.
Many thanks
