3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Mirror reflection problem 3ds max / Mental Ray
8 REPLIES 8
Message 1 of 9
1077 Views, 8 Replies
Hi all.
i´m having a problem with max and mental ray, when i render an image, the reflection in the mirror looks stained, i tried various combinations in the FG and GI values always with the same result. the curious thing is that if i do an area render of the mirror it looks fine, if i move the camera to some angle it looks good but the point is that im doing a walk trough so there´ll be some angles that will look awful if i dont correct this error. In the attached file you can see what is going on.
Any help will be greatly appreciated. Thanks
8 REPLIES 8
Message 2 of 9
having same problem
Message 3 of 9
PROH
Hi. We might need a bit more information. What Max version are you using? How are the FG (and GI?) being calculated? What are your FG map settings? (GI map?).
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
Message 4 of 9
in reply to: PROH
Thanks, already found the problem. I had to use FG Point Interpolation and
check the box to use "Use Radius Interpolation Method (Instead of Num. FG
Points)"
Seems to be that everyone is saying its a bug in 3ds Max 2014. Nevertheless
the less it works now.
Thanks for following up.
Message 5 of 9
Did you ever find a solution for your problem with the mirror reflection?
I am having the same issue in 3ds max 2016 and cant find a solution.
Message 6 of 9
Render Setup>Global Illumination>Final Gather>FG Point Interpolation>Use Radius Interpolation Method  (check box) (default unchecked)
Let me know if this worked for you. It did for me.
Message 7 of 9
I dont have that setting?
did i miss something maybe?
Message 8 of 9
I guess they changed the Render Setup menus in 2016. Sorry.
Message 9 of 9
It would seem that way.
Anyone got any idea for 3ds max 2016?
Derek Cerciello
Architectural Technologist
