3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Mental ray Final gather
3 REPLIES 3
514 Views, 3 Replies
Hello , i have different picture after render via console and via 3dsmax programm with use mental ray and enable final gather in scene.
My console command --
"C:\Program Files\Autodesk\3ds Max 2014\3dsmaxcmd.exe" -outputName "D:\new folder\Scene\newImage.jpg" -w 800 -h 600 "D:\new folder\Scene\newscene.max"
Left picture via programm, right via console.
2015-01-27 10-32-19 Скриншот экрана.pngThanks.
3 REPLIES 3
how create command via console that FG calculating&
Personnally, i can't see the difference between your images.
One thing is certain, if both configuration use the same settings, same file format, you should have the same image.
Heres a link with the complete informations about command-line rendering.
And i have attached a simple test that i made here, with a simple cornel box, with the settings a little bit exagerated.
Image 1 rendered in Max 2015 without Final Gathering.
Image 2 rendered in Max 2015 with FG
Image 3 rendered in command-line (with your settings).... you can see that this image has been rendered with FG, like the image 2
Image 2 and 3 are identical and you can see the difference with the image 1 without FG.
Brock_Lafond
The image on the right looks like it has a different gamma settings.
Try rendering to openEXR without gamma and then correct the images in post with the same settings. They should render out the same.
Alias/Wavefront Maya 3 -> Discreet 3DS Max 4 -> ...
Win7 Pro 64
EVGA Classified Super Record 2
Dual Xeon Hexa-Core, 48GB RAM
GTX 780 x 2
Corona Renderer, mental Ray
