Hi, how do I make the rendered frame window the actual size in pixels of the rendered image? I am currently setting Output Size in Render Setup to Custom, width: 1024, height: 768 and the image renders to that size ok.
But, the rendered frame window only shows the image at half the actual size. When I view the actual image in Gimp, the image is the correct full size, so I know it is rendering properly. I just want to be able to see my image at full size when I render to the rendered frame window. Any help?
By the way, my screen resolution is 1366x768. I know that if the rendered frame window is actual size, I will probably have to scroll just a little bit to see the full image. That's ok with me. I'll be able to see most of the actual image at that size (1024x768).
Also, I'm aware that you can use the mouse wheel to zoom in, but then I have to resize the window as well. Doing this every time I render is annoying. Can't I accomplish the same thing with a setting somewhere?
