3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Light with Key
2 REPLIES 2
407 Views, 2 Replies
Light with Key
Hy everyone!
I have a problem with my light, when i create it, it has key animation on it, and i can't move it. in all of my scene, every time, even if i re start it or reset it.
Can you help me?? it's doing this in all light, standard, Vray or photon Light!
i'm lost and found nowhere the answer!
Please save me!
Mel
2 REPLIES 2
BenBisares
My guess would be that you changed the default controller of lights to something like a "position constraint" which would explain the keyframe.
Create a light and then go to the "Motion Panel" (see image below) and click on "Position". From there click on "Assign Controller" (the icon with the check-mark just above and to the left). From there make sure that the default is set to "Position XYZ".
User-added image
​Let me know if that works.
Ben Bisares
in reply to: BenBisares
Yeahh perfect, you are an angel!!
