Large format renderings for print/Arnold netowork rendering with single node
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
The project.
Currently working on a few pieces for print. Creating them in 3ds Max, rendering with Arnold. Test renders all look great at 1920 x 1080 (roughly). I have all my files set to go when I run into the problem.
The problem.
The final dimensions of what we want the prints to be is, roughly 4 feet wide by 3 feet tall. Shooting for around 175 dpi to start. Trying to render this outright causes, eventually, the system to freeze up, blue screen, or just generally throw an error before it can even get to half way through the render. Even the initial first pass that just blocks in everything before buckts come up is beyond sluggish. The solution that I discovered worked a few months ago, which was to use backburner to do strip rendering (render individual strips of the image and then at the end they are stitched back together into one image file by backburner). When I initially did this about a month ago, it worked out just fine. I got exactly what I needed about 2 hours after I started the render which was a lot better than I thought it would be. Fast forward to today and I've got watermarks. Backburner can not find the license it says. Now, here is the questions.
The questions.
1. Does anyone have a good way of rendering very large images for print via 3ds max Arnold?
2. Every copy of 3ds max comes with a license for Arnold correct? So why does it not recognize the license when I try to do a single note network render when that single node is the PC with the 3ds max license on it?
3. Has Autodesk and Arnold render changed its licensing policy to only be a 30 day trial of some sorts when it comes to the license that is attached to 3ds max. The reason I ask this last question is because recently there was an update to 3ds max and I didn't think anything of it. On my work pc which I use every day, today after all these issues I went into arnold license manager and it said that my 30 day free trial was up, however on my home computer which these days I rarely load up 3ds max, and just updated it today, it says that I have 30 days left on a trial (I own Autodesk licenses for both !).
I apologies if this is not where this question belongs, or if this doesn't quite make sense, but I have look for the past 6 hours for an answer, consulted our IT department and have submitted a ticket to Autodesk (still waiting on that response) and have found no solution.
