Hi, i just installed the most latest 3ds max version which is 3ds Max 2021, vray 5. Just wanna know is material subdivision unavailable in this version of vray? Because in the previous version of 3ds max (2017) that i used always have this subdvs option in my material slot.
Solved by JonasVidal. Go to Solution.
Dear friend, the subdivisions factor no longer comes by default in vray in both lights and materials, which for users who used previous versions brings big problems, the good news is that you can activate them again with a script that has generated chaos group for that type of case, another is that you handle the image sampler tab (antialiasing) and vary the factor that comes by default (6) by 25 and with that you will see decent results both in materials and in factor as the light throws in bounces and noise of the image, at greater values āāof (25) greater time extensions. and another would be to work with the bucket image sampler tab and give increment values āāin Max subdivision that comes by default in 24 by 100 for example ... and the value of noise treshold from .01 to .005 In my particular opinion of these two modes, the first one is the fastest since it does not depend on the noise Settings
