3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
How to change bump direction in advanced wood?
4 REPLIES 4
travis.designer.vn
365 Views, 4 Replies
Hi
I have wood block 500x1000x30
I apply Advance wood material. Change direction into Y axis. It look good with right direction of wood ring.
But I try increase Bump. It will show wrong direction of bump. How can I fix it?
Thank
Travis
4 REPLIES 4
is it bug? are there any solution? or waiting for autodesk fix it?
Thank
Travis
madsd
in reply to: travis.designer.vn
For refference, I used Arnold.
Works fine.
travis.designer.vn
in reply to: madsd
Hi
I tried with corona renderer.
Could you share with me more detail of processing.
Did you try with other renderer such as corona or vray?
Thank
Travis
madsd
no.
I removed all Corona related stuff and it started working
