3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
How do you turn off "Physical Sky" background on a Arnold render so it is transparent?
4 REPLIES 4
jeff_swann
428 Views, 4 Replies
Need the Physical Sky lighting effect influence on assets, but not the actual background image in an Arnold Render.  Is there a button somewhere where you can turn off background like in Maya?
4 REPLIES 4
CiroCardoso3v
in reply to: jeff_swann
Open the render settings, go to the Environment, Background and Atmosphere section
In the Background Backplate you have several options.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
jeff_swann
Thanks for your response, but I still get a background with background (BG) = NONE in Arnold Environment settings - see image.  Also, Arnold Render View and actually rendering out frames gets the same BG in all.  About to switch to HDRI lights to get alpha again as PNG rather than Physical Sky dome.
CiroCardoso3v
Are you using a Skydome light for the Physical Skydome? If so, you need to untick this option called Light Shape Visible
Ciro Cardoso
jeff_swann
Outstanding solution - knew an Expert could quickly solve my beginner problem - THANKS!!  Thought this tick-box was just for viewports.
