How do you create a color map (like a baked room) for a game that has shadows baked in?
heynewt
heynewt
I work in Unity and Modo, and both use emissive color maps for baked object materials that have all the lighting baked in.  In those cases the baked texture is applied as an emissive color map.  If I try that approach in MAX, applying the same texture as an emissive color map to the object's material, I get no result at all except a white (or whatever color is selected in emissive properties) surface.
oliver
It will be displayed when you switch your viewport to High Quality-mode.
But it will not illuminate the scene in the viewport.
domo.spaji
No, it will not!
It will not be displayed in rendering either.
Can't understand how so many people believed Zapp Anderson lies. And so easily transferring that to others.
I mean his name is Zapp... Or is it?
Also, can't understand how someone take for normal blind working on shaders/materials, maps in any 3D software!?
oliver
Texture applied to Emmission-input, viewport set to High QualityTexture applied to Emmission-input, viewport set to High Quality
Texture applied to Emission input, viewport set to Active ShadeTexture applied to Emission input, viewport set to Active Shade
heynewt
Thanks for the replies.  Switching to High-Quality did it!  I was building models for game use, and never thought to try and render it (which also would have shown it was right).
domo.spaji
With default values like on your shot you'll have pretty close result to pure white.
If that's write to you, than ok.
There are shaders for that purpose, no slots, no settings...
And no option to "show realistic material" aka "High-Quality" in them.
There's also viewport rendering style for turning all materials to "self-iluminated"
heynewt
Thanks for that insight.
