3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Flicker Render Hair
1 REPLY 1
347 Views, 1 Reply
Flicker Render Hair
Hi, I have a problem.
When I render a few frames, a noisy flicker shows in the hair of the character. I'm using Vray and Hair Farm.
I already played with Subdivs and Interp. Samples in the Irrandiance Map.
Anyone here know what other thing can I do? Is just in the hair, the rest of the model is clear.
1 REPLY 1
Francisco_Penaloza
Actually, for hair or similar very thin object it is an antialiasing problem,  Sometimes Gi has problems with those objects too but is mostly antialiasing.
Now if you are doing animation, I would not recommend using Irradiance for hair object, I would recommend brute force.
Could you post some images and setting of your scene?
Did you try checking the box of detail enhancement in irradiance options?  That will brute force those small areas for better light distribution and antialiasing.
Technology Administrators
