3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
finalgather filter is deprecated, value 0 is recommended.
5 REPLIES 5
1269 Views, 5 Replies
How can i fix this problem:
I'm using 3DS Max 2017.
I need help.
Thank you
Dora Santos
5 REPLIES 5
Richard.Vivanco
Are you working with photon mapping enable too??
Check your diffuse bounces, if you are working with PM, put 0 in the value of diffuse bounces.
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Website | Youtube | LinkedIn
in reply to: Richard.Vivanco
Thankyou for you answer but i'm not working with PM.
Attached i sent you a image of my scene and render settings.
Some objetcs are gray and i dont know why?
Kan you help with the settings?
Thank you verry much.
Richard.Vivanco
If you work only with FG you need diffuse bounces, try with value of 3
Change your noise filtering to NONE
But in my opinion, you need another indirect illumination solution.  Normally in interior scenes with small windows you need FG+PM, put a skyportal in your window too.
Maybe this video can help you, its in spanish but easy to follow
https://www.youtube.com/watch?v=-zIk72dtv_Y
Richard Vivanco V.
Thank You . I will try.
Best egards
Dora
Thank yor for the video it's very goed. It was easy to understand because i'm Portuguese.
Best regards,
Dora Santos
