ERROR MESSAGE WHEN ATTEMPTING TO RENDER
moycoas
moycoas
Hello, newbie in this forum.
When i try to render my scene, i get the following message.
An exception occurred while rendering with 3ds Max.
This render will abort. If you render again without resolving the exception, you may experience instability.
Unknown Exception.
I have realized, that if i hide the lest half region of my scene, i can render with no problem, but i tried to isolate every object and i dont know yet which is the problematic object.
Could someone with a gold heart be my savior and with your advanced knowledge, plugins or scripts check my scene and help me realize which is this object that is not letting me render?
3ds Max 2019
Attempting to render with corona renderer 4
miledrizk
Open a new Max file, and from the File - Import, choose Merge,
Now when you choose your scene you'll be presented with a list of all the objects inside,
Select a few of them and merge, try to render now using the same render settings,
If all is good, save the file so you can preserve your clean geometry and Merge again a new
Set of objects, repeat the process until you find your problematic object/objects
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
I had the same problem with the same rendering engine. (Corona) My scene was heaavier on xfres, so i started debugging and finally i find it! I xrefed some "corona lights" to my scene and that was the problem, on the other hand materials that "corona light material" mapped doesn't cause any problems. After i deleted that xrefed lights, even though i get "corona error messages" on the error panel like "Autodeks generic mat." or "Normal map problem" i can still render.
So, the problem was xrefed corona lights, not that material errors in my case.
