Hi.
When i use distributed rendering the extra nodes sometimes render different results. They're normally too bright. This only seems to happen when i use a HDR image and rendering with IBL. I'm assuming this is a gamma issue but i'm not sure how to alter the nodes to be the same as my machine. Anyone know the answer?
Andy
Hi.
Andy
Solved by tony.su. Go to Solution.
Thanks Richard.
The trial license has ran out on some of the nodes so i'm unable to load max and update this way. DO you know of a way to do it outside of the max interface?
Thanks Richard.
C:\Users\USERNAME\AppData\Local\Autodesk\3dsMaxDesign\2014 - 64bit\ENU\en-US\defaults\DesignVIZ.mentalray\
Your version of Max may be different, but you should be able to find the final folder. In there is a file called CurrentDefaults.ini which you can easily edit in Notepad. Fine the section for Gamma and check/adjust the values in there for each of your render nodes. In all likelyhood, you should be able to modify one file then copy/paste it to the rest of the machines without causing any problems.
Chris Medeck
Chris Medeck
Thank you.
I looked at the file and gamma seems to be correct! I've attached a 3ds max file and the free hdr image from cgtextures so that someone can test it on their setup. Ive also attached the render that I've output. I've done a few tests now and it's only when i use IBL. everything is is fine using FG.
Also just reitterate, this problem is occuring only when using distributed rendering, when i send renders to backburner the outputs are correct.
Thank you.
which system do you use?
Satellite Systems or Host Systems with mental ray Standalone Installations?
The version of mental ray must be match. Could you tell me which version of 3ds max do you use? and the version of Satellite Systems or the version of mental ray Standalone.
Hi Tony.
We use 3DS max 2014 SP5 and distribute render using Satellite systems. In other words our workstation and render nodes all have a full version of 3DS max installed, not the mental ray standalone.
I'm not sure how to find out which version of Mental ray we use, but every machine has the same install. It's also worth me noting that i've tried the test scene on a few pc's using different nodes and recieved the same issue.
Andy
Hi Tony.
Andy
I found Distributed Maps is on. So did you copy every map to your slaves? If not close Distributed Maps.
This is explain about Distributed Maps.
Distributed Maps
When on, specifies that all texture maps can be found on each of the slave machines doing distributed rendering. This saves time by avoiding the necessity of mental ray distributing all the maps to each slave via TCP/IP. When off, specifies that all maps used in rendering reside on the local system; that is, the system on which you start rendering. Default=off.
If Distributed Maps is on but the maps are not found on the slaves, those maps simply will not render on the slaves, and rendered output will be incorrect. Also, an error message will appear in the mental ray message window.
If you are doing local rendering only, this setting has no effect.
Maps on all systems in distributed rendering must have exactly the same name and directory path.
Distributed Maps
All the maps are saved on our network so i shouldn't have turned this on. I've just retested the scene with it turned off and i'm having the same issue.
The render issue only applies when using IBL. If i turn this off and use only FG, GI or nothing, the issue doesn't appear.
I've just done another test using the same test scene i uplaoded earlier. But this time i removed the skylight and instead lit the scene with MR sun and sky, which means there are no textures. The same issue occurs even with the physical sky as the light source for IBL.
We couldn't reproduce your issue,
To remove the user profile:
C:\Users\%username%\AppData\Local\Autodesk\3dsMaxDesign\2015-64\ENU
C:\Users\%username%\AppData\Local\Autodesk\3dsMax\2015 - 64bit\ENU
*modify the version and architecture to suit the case
When 3ds Max is launched a new ENU folder will be created. If the issue has not been resolved, users can revert to the previous settings by deleting the new ENU folder and renaming the old one back to what it was.
Depending on the language 3dsMax/Design is running with, the folder can also have the name FRA, DEU,...
Note: In case users cannot see the folder "AppData", please ensure, that the user has enabled "Show hidden Files, Folders and Drives" within the Windows Explorer > Tools > Folder Options.
I'm experiencing the same problem.
I'm currently running 3ds Max 2014 SP3, with matching Max and Mental Ray installs on my render farm nodes.
Steps to reproduce:
1. Add a teapot to the scene
2. Select menu option Create/Lights/Daylight System and drag out the Daylight System
3. Choose Yes, add mr Photographic Exposure Control
4. With Daylight001 selected, go to Modify tab
5. Change Sunlight to mr Sun
6. Change Skylight to mr Sky
7. Choose Yes, add mr Physical Sky to Environment
8. Go to Render Setup/Processing/Distributed Bucket Rendering
9. Select Distributed Render
10. Render the scene
Result:
Buckets rendered by render farm nodes have a different appearance from locally rendered buckets.
Steps to reproduce:
Result:
Could you try SP5.
Download sp5, install it on local and slave.
Could you try SP5.
Hi Tony.
I'm having trouble finsing some of the information you mentioned. I've attached a .txt file which includes the information i can see.
'Do you install Max Design 2014 SP5 on both local and slave?'
Yes it's installed on all our pc's. And i've tried rendering the same scene out on different combinations of pc's to ensure it's not just mine.
Hi Tony.
Sorry for my last message. I gave you wrong hyperlink.
But I don't understand if you install max 2014 sp5 why mental ray version on your slave is 3.11.1.5.
"JOB 0.0 10 MB info : started threads 0,1,2,3,4,5,6,7 on animage-1:7520 now known as host 1
MSG 1.0 4 MB info : version 3.11.1.5, Feb 20 2013, revision 191037"
You can get it from mental ray message.
JOB 0.0 23 MB info : started threads 0,1,2,3,4,5,6,7 on SINSGH305BD8Q:7520 now known as host 7
MSG 7.0 4 MB info : version 3.11.1.10, Jul 9 2013, revision 200304
The version of mental ray on my slave - SINSGH305BD8Q is 3.11.1.10.
And The version of mental ray on my local -
So could you check the 3ds max version.
And install max 2014 sp5.
Hi Tony.
I've installed SP5 and the issue has been resolved. Sorry for wasting your time as I could have solved this if i correctly checked the update.
Thank you for your help and time.
Andy
Hi Tony.
Andy
Upgrading to SP5 resolved my issue. Thank you!
