Default Shader
Default Shader
Default Shader
In the compact material editor, is there a way of changing the default shader type from standard to arch & design?
I never use the standard shader, it would save a few clicks if unused material slots were already defaulted to arch & design instead of standard.
Thanks.
ekahennequet
Thank you, this is exactly what I needed.
