Copy Render Settings from one .MAX file to another .Max File.?
sdeters
sdeters
Is there way to copy all of arnold render settings from one .max file to another .max file?
madsd
Use the presets second entry in the main render panel.
Adjust a bunch of things ---> "Save Preset..." then reset max, and load the preset to inject the settings on any scene.
sdeters
It is right there clear as day.  How did I miss this.
Thanks for the feedback and help.
Have a great weekend.
madsd
Can't see the forest because all the trees are blocking the view, kinda thing LOL.
I've been there myself 🙂 ( earlier today I was looking for my computer glasses, went downstairs, outside, in the greenhouse, then had to look in a box where I sometimes put them, then put on the glasses to be able to see properly ( then went whaaat? they had been sitting on top of my head all the time )
emmerson.richard
Another quick approach other readers might use:
In your new document
File > Import > Merge (navigate to the old document with the render setting you want). In the Merge dialogue window that opens, tick Render Settings box (and untick others if it is hard to see the render setting), select Render Settings and okay the Merge.
