Color Correction - is there only one node in 3dsMax?
Alexx31
Alexx31
when I need color corrections in 3ds Max (Vray) I can find only one "Color Correct", which is very limited.
Are there other nodes?
I mean color balance, selective color correction etc. as known from Photoshop.
With Color Correct I have no chance to shift only all red tones more to yellow for example.
Thanks for help
CiroCardoso3v
You also have the OSL Color Correction node
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
syndicate5
This must have been introduced in versions after 2020 because I cant find it.
https://www.instagram.com/the_3rdkind
MartinBeh
OSL is available in 3ds Max 2020 according to https://help.autodesk.com/view/3DSMAX/2020/ENU/?guid=GUID-568DA829-62DA-432F-814F-2600F65141BD
And the code for the shaders is available at https://github.com/ADN-DevTech/3dsMax-OSL-Shaders/tree/master/3ds%20Max%20Shipping%20Shaders
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
