Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Caustics / System Unit Query
ah254
Message 1 of 8
ah254
How do caustics respond to system units? I was using max in inches but I'm now modelling a brand new scene in mm and it seems impossible to get caustics to show up regardless of any setting. Any ideas anyone?
Adam
Replies (7)
Message 2 of 8
CAMedeck
Make sure your System Units are changed to mm, and not just your Display Units.  The renderer should understand the units being used, and scale things accordingly.  Are your objects correctly scaled for the environment?
Chris Medeck
Message 3 of 8
ah254
Yes both my display and system units are now mm. Material is physical glass. I've attached one model of a larger object from when I used inches and a smaller object now that I'm using mm as system units. With identical settings the caustics only generated in inch model. Even with the caustic photons bumped right up to 90 million it failed to generate, think I'm missing something but have no idea what it could be! How might I go about checking my objects are correctly scaled for the environment?
Adam
Message 4 of 8
CAMedeck
You've got one small scene (mm) and one large scene (inches).  Of course the lighting and caustics will behave differently since the light is traveling so much further.
Is it intentional to have one scene so much larger than the other?
Chris Medeck
Message 5 of 8
ah254
Yes I've been playing around with how scale effects it, with the smaller model (mm) it seems impossible to have the caustics show up at all. What setting is best to play around with? I think I've tried most things but nothing seems to happen.
Adam
Message 6 of 8
PROH
Photometric light behave according to the scale. So if you want real world realism, you objects should be scaled "real". A glass vase being 4,5 meters high, isn't something I see everyday, and it will of course create a different caustic effect than a vase being 35 cm high.
It's your choice wether or not to follow these guidelines, but don't compare to such different setup.
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
Message 7 of 8
ah254
It doesn't have to be a vase, it could be anything, sculpture etc. I've just been trying to figure out how the settings should be amended according to different scales. It was actually the 4.5m model that generated the caustics strangely enough. I would have thought it would be more difficult to generate caustics on larger objects given the extra distances. I will keep testing through and amend the photometric settings for the smaller model.
Adam
Message 8 of 8
ah254
Ok think I've figured it out! Just had to drastically increase energy from photometric light and then adjust exposure. Thanks for your assistance!
Adam
