3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Can't reload uberbitmap
4 REPLIES 4
magnus.flink
323 Views, 4 Replies
The uberbitmap does not reload when saving over a file. Making a new node doesn't help. Is there any way to force it to reload?
4 REPLIES 4
oliver
in reply to: magnus.flink
Try loading another file and then switch back to the desired one.
magnus.flink
Tried it, but it still loads the original, and not the modified one.
oliver
Then try the BitmapLookUp-node - that one should do the trick.
domo.spaji
Where do you checking that?
Mat. Editor, viewport or offline rendering?
Looks like Arnold hardest holding on cache.
To the point where only loading other file helps - so load copy of that bitmap.
You can only trust on what you see in Material sample (by default locked to current renderer)
All other loaders and places can show updated image/material.
