Hello, everyone. Some time ago I wrote here about a black screen when rendering. I did several new projects and
had no problem. But today when I try to render I get a black screen again. I can't figure out where the
problem is coming from, I have lights, the settings are ok, everything is as it should be,
but I'm not getting a render. Only IPR render works. I can't upload the file because it's too big
and I don't know how to reduce it. The problem is only in this file. Could you help me again?
Thanks!
https://forums.autodesk.com/t5/3ds-max-shading-lighting-and/render-problem/m-p/12154991#M40313
Solved by darawork. Go to Solution.
Just a guess, but maybe the camera might be inside something like a wall? If you turn on viewport clipping and slide the near clip distance arrow upwards does it fix the problem?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Viewport-Clipping....
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
Thanks for your reply. The camera is not behind a wall, it is set just right. I started removing objects
and furniture and that's how I fixed the problem. Maybe the problem was in one of the furniture.
