3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Arnold Visibilty to Camera
5 REPLIES 5
rhasell
575 Views, 5 Replies
Hi
First off I am not a 3dsMax expert, and muddle my way though it for my limited needs.
I need to do various sun studies with shade structures. Previously I used the "Mr Sun" and Scanline Render.
I am now trying the newer Arnold Renderer with Sun Positioner instead. I do prefer this method.
I am unable to turn off the visibility of the Shade roof in order to only see the generated shadows. I have tried the only solution I found on the forum, of a double sided material, but either I implemented it incorrectly, or it just does not work?
If the "Visible to camera" setting does not work, then what can I do? All I want to see are the shadows, and in my case I will allow the edge cables to be visible to camera to show the outline of the fabric roof, but not the roof its self.
Attached sample image of a quick test, ISO view for clarity.
Reg
2025.1.2
Please Accept as a solution / Kudos
5 REPLIES 5
CiroCardoso3v
in reply to: rhasell
Add the Arnold Modifier to that surface.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
rhasell
in reply to: CiroCardoso3v
Hi
Thanks for the reply, but could you explain a little more please.
I was under the impression that I had already done that, but it does not work, so I am doing something wrong. My skill set is not sufficient enough to understand your comment.
Even as a test, I made a plane, placed a teapot on top of it, tried to hide the teapot from the camera, nope, does not work, its still visible.
version: 3ds Max 2022, SP1
Reg
2025.1.2
rhasell
Hi
Found it, thank you.
This one?
Reg
2025.1.2
CiroCardoso3v
Yes that one. Is it working?
Ciro Cardoso
rhasell
Hi
Yup, got it working, thank you for your help.
Reg
2025.1.2
