New to Arnold here, so I am trying to figure things out that I knew well in Mental Ray.
Arnold renders backfacing polygons. The only way I have found to avoid that is to apply a Double-Sided Material with a Transparent Material (thin -walled) in the back material slot.
Is there another way?
Tim
Solved by Stephen.Blair. Go to Solution.
Add an Arnold Properties Modifier to the object and disable Double-Sided.
https://support.solidangle.com/x/vIJsAg
