Hi guys, can anyone help me with the Arnold render? It won't render the top part of any mesh. I have tried in perspective mode and camera mode but the top part is totally cut off.
Solved by CiroCardoso3v. Go to Solution.
At a first glance it seems you are using Displacement. You probably need to adjust the Bounds Padding.
You can find more info here
And also here
https://www.youtube.com/watch?v=Za2ME2T7odM
And also here
Thanks, you've solved my problem
