So I used 3dsmax 2019 before update of arnold and photometic lights works . Now I choose a photometric light and add an ies file and it sorta works but as soon as i choose the radius of the light 3dmax crashed and i dont even get an error report. Is there anyone that has encountered this and if so how did you solve this issue?
Please any help would be highly appreciated!
Solved by Stephen.Blair. Go to Solution.
I can confirm that. 3ds Max 2019 with Arnold 2.2.961.
Arnold Light set to Photometric, IES-file loaded = works
Arnold Light set to Photometric, IES-file loaded + Radius tweaked = crash
Same problem.
p.s. kick.exe also crash without drop error message. So it seems it's Arnold's bug, not MAXtoA.
This is already fixed, and the fix will be in the next Arnold update.
