3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Arnold light
6 REPLIES 6
mikkoYWYF7
799 Views, 6 Replies
Arnold light
HI
I´m First time Arnold user. Hope somebody could help me with this.
Adding more Arnold light or changing intensity don´t do anything. Keep on getting same result?
I´m confused.
Thanks.
Mikko
6 REPLIES 6
madsd
in reply to: mikkoYWYF7
Your lamps may be too weak, sit too far away, and thus does not realy contribute to the lightning.
Upload a teapot on a plane and some lights to the thread and Ill take a look at it and help you fix the workflow issue.
mikkoYWYF7
in reply to: madsd
Thanks.
Here´s test file. If I change light settings can´t get any results.
Mikko
madsd
Don't use the environment color to add skylight.
Use an arnold Skydome light.
And increase the power of the lamp you use till it starts to illuminate your scene like in the video I made here, correcting the set, so it plays nice.
Depending on your scene scale you may need to use large numbers, or very small numbers.
madsd
Forgot to mention, dehook "Normailze" energy" If you for some reason work in an obscure unit set/scale. This way you can keep the values lower, if you dont like big numbers.
mikkoYWYF7
in reply to: madsd
Thanks. That was very helpful.
Mikko
madsd
Please accept as solution, so my post gets green and flagged if it was useful.
