3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Arnold cryptomatte sequence is giving me different colors
3 REPLIES 3
alkaf_salem
314 Views, 3 Replies
Hi
Im still new to Arnold and im trying to use cryptomatte in the composition
so far it was working fine but now I have an issue which the solid colors it gave are different each frame, its not stable to the same color
also as you guys can see in the attachment my arnold volume object cannot be read in cryptomatte , is there a way to make it readable ?
Labels (1)
3 REPLIES 3
CiroCardoso3v
in reply to: alkaf_salem
Can you provide the scene for testing?
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Stephen.Blair
What version of MAXtoA? You need to use at least 5.6.10
Help | 5.6.1.0 | Autodesk
  • MAXTOA-1538 - Fixed a bug where node names in the Arnold scene changed from frame to frame. This caused incorrect results when using Cryptomatte.
// Stephen Blair
// Arnold Renderer Support
teamSP26J
It was bothering me as well, update or check this option.
