3ds max render output size preset resolution buttons show only four not six
dennis
dennis
3ds max render output size preset resolution buttons show only four presets not six. I'm not sure when this changed, as I haven't need 6 render preset buttons for a while. The 3dsmax.ini file still shows setting for six buttons, but the actual interface only shows 4. Is there some place that I can change the display to show all six? thanx --ds
tony.su
Autodesk Support
Autodesk Support
I don't think you can change it to 6. I believe the version you told about is very very old.
Now you can Configure Preset using right click on any preset resolution button, instead of edit ini file.
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/3DSMa...
Tony Su
Product Support
dennis
Thank-you for your answer, but I'd like to know for certain if there's a way to change the display to show all six buttons. Anybody?
madsd
If you look at the area you can see that the 4 boxes are cramped in there, there is no room for 2 more in the way the UI is set up.
At some point, the render panels front  gets smoked and rebuild, until then, keep things like they are and don't touch it basically is the way the dev will think about this particular request.
You can download scripts that can manage many resolutions for you. 1 in particular looks good $5 for full version with multiple resolutions pr camera.
Looks legit and way better that what 6 buttons can offer, so give it some thought.
