3DS Max 2023 - Arnold Renderer Bugged
jgjYRRKE
Message 1 of 24
jgjYRRKE
Hi all.
I have discovered 2 errors when using 3DS Max 2023 and Arnold Renderer.
1. When rendering colored particles (made with tyFlow) the viewport displays the colors correct.
But when rendering there is a problem (image 1).
2. When using BlendedBoxMap the Active Shade renders bump map correct, but when switching to production render it goes wrong (image 2).
Anybody know how to fix thoose problems?
Thank you 🙂
Replies (23)
Message 2 of 24
wernienst
Have a look to your Render Setup. There may be different settings for Production, Interactive and ActiveShade modes: CPU or GPU, Arnold Compliant or 3ds max Maps Support etc. Some shaders/maps are compatible, some not.
Message 3 of 24
CiroCardoso3v
And just to add you no longer need to use ActiveShade to have an interactive preview. You can use the Arnold Render View
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Message 4 of 24
jgjYRRKE
Thank you for your answers.
Still having the problems though.
So if anyone have a solution, please chime in.
I know about the Arnold render view, but never got around to using it.
Force of habit I guess? 🙂
Message 5 of 24
CiroCardoso3v
Can you provide the scenes? Without them, it is hard to know exactly what is wrong on your side.
Ciro Cardoso
Message 6 of 24
jgjYRRKE
Hi Ciro
I have one of them on this PC, but I use the tyFlow plugin to make the particle flow.
Do you have that?
Anyway here is the scene.
Message 7 of 24
jgjYRRKE
Just recreated the other scene.
I think it is a tyFlow problem.
The object renders fine in both Active shade/Production render.
After turning to particle, it renders fine in Active Shade but wrong in Production render.
Attaching the scene file and bump map used.
Message 8 of 24
CiroCardoso3v
Thanks for this. I will need to install the free version.
Ciro Cardoso
Message 9 of 24
jgjYRRKE
That is the one I use....for now.
Plan on buying it tho.
It's an amazing plugin.
I spend hours playing with particles 🙂
Message 10 of 24
wernienst
@jgjYRRKE
To your 1st problem:
when I change Mapping Mode to Affect particle mesh UVWs I get this:
(using 3dsMax 2024.2.1 and tyFlow Free 1.103)
Message 11 of 24
jgjYRRKE
That worked.
Thank you ❤️
Weird that I only needed to do it when using Arnold renderer tho?
Nevermind, it works 🙂
Message 12 of 24
CiroCardoso3v
Based on the scene you provided, I don't see any difference between Active Shade and Production Render.
Ciro Cardoso
Message 13 of 24
jgjYRRKE
That is so weird, since I use default render settings.
Anyway, the fault must  be with me, somehow then.
Thank you for your time, Ciro ❤️
Message 14 of 24
CiroCardoso3v
You are welcome. Remember that any render settings you are using in Active Shade aren't copied over when you move to Production rendering. That is why I recommend using the Arnold Render View for IPR.
Ciro Cardoso
Message 15 of 24
jgjYRRKE
I have been playing around with Arnold renderview since you mentioned it.
It's great that you can add color correct, vignette and stuff directly.
From now on I will use it more.
Try to get used to it.
Thx for the tip 🙂
Message 16 of 24
nlpprakt
Observer
Observer
Greetings, please support me - I am using 3ds max 2023. You recommend using arnold render view. I opened it, added color correction in the posts tab, etc. Now, when I want to perform the final high-quality rendering and press the F9 key, the end result is very different, because the elements added to the Arnold render viewer, such as color correction, stop working in the usual standard 3ds max render window. I know that this problem was solved in 3ds max 2024. But for technical reasons, I have to work in version 2023. How do I make the final render result look the same in both windows?
Message 17 of 24
wernienst
Strange. I have max 2022 here and it works. All imagers I have added in Arnold RenderView's settings panel are also present in the Render Setup: Arnold Imager list. However, keep in mind that you cannot use both render views simultaneously.
Message 18 of 24
jgjYRRKE
Yes. Very weird 🙂
Message 19 of 24
CiroCardoso3v
Do you mean you cannot see the same result on this window?
When I press F9 I still use the Arnold Render view to render the final image.
Ciro Cardoso
Message 20 of 24
jgjYRRKE
Correct.
The original Active Shade window shows some thing different from the Production Render.
When using Bercon tile I also have to use production render to get the correct image.
I can work with it tho 🙂
