i rendered a shot but the light and the material are not right at all i tried to modify the render settings , the camera setting but i cannot actually get it can some one help me withe problem?
Hi Semsema,
Thanks for your question. At a glance, it looks as if you should increase your Irradiance map samples in your settings, but it's difficult to tell without getting a bit more information here.
Also, since V-Ray is sold and maintained by The Chaos Group (not Autodesk), for the quickest answer to any V-Ray rendering-specific questions, you might post your questions on their technical support forums so they can answer you directly with render settings feedback.
Thanks again, and good luck with your renderings!
Take care,
